Ana içeriğe geç
Acer Chromebook CB3-431-C5EX Speaker Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-431-C5EX Speaker Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Speaker Replacement: adım 3, 2 resimden 1. Acer Chromebook CB3-431-C5EX Speaker Replacement: adım 3, 2 resimden 2.
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Speaker Replacement, Internal Speakers: adım 4, 1 resimden 1.
    • Remove the two 4mm Phillips #0 screws securing the speaker.
  5. Acer Chromebook CB3-431-C5EX Speaker Replacement: adım 5, 2 resimden 1. Acer Chromebook CB3-431-C5EX Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the speaker from the computer.
    • Repeat the previous steps to remove the second speaker from the computer.
    • Note that the two speakers are connected by a wire, so you must replace both of them.
  6. Acer Chromebook CB3-431-C5EX Speaker Replacement: adım 6, 2 resimden 1. Acer Chromebook CB3-431-C5EX Speaker Replacement: adım 6, 2 resimden 2.
    • Disconnect the speaker wire from the circuit board by grabbing the plug by its plastic edges and gently pulling it straight out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Cayley Ho
545 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G3
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,026
