Ana içeriğe geç
Acer Chromebook CB3-431-C5EX Trackpad Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-431-C5EX Trackpad Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 2, 1 resimden 1.
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 3, 2 resimden 1. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 3, 2 resimden 2.
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Trackpad Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 5, 2 resimden 1. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 5, 2 resimden 2.
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 6, 1 resimden 1.
    • Carefully lift the entire battery pack out of the laptop.
  7. Acer Chromebook CB3-431-C5EX Trackpad Replacement, Trackpad: adım 7, 2 resimden 1. Acer Chromebook CB3-431-C5EX Trackpad Replacement, Trackpad: adım 7, 2 resimden 2.
    • Remove the black tape covering the screws connecting the trackpad to the laptop.
  8. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 8, 1 resimden 1.
    • Remove the three 2.5 mm screws that are securing the trackpad to the laptop using a Phillips #0 screwdriver.
  9. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 9, 2 resimden 1. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 9, 2 resimden 2.
    • Lift up the black retaining flap on the connector.
    • Slide the blue ribbon cable out of the connector.
  10. Acer Chromebook CB3-431-C5EX Trackpad Replacement: adım 10, 1 resimden 1.
    • Lift up the body of the laptop and slide the trackpad out from beneath.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 174
