Ana içeriğe geç
Acer Chromebook CB3-431-C5EX Wireless Card Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: adım 2, 1 resimden 1.
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: adım 3, 2 resimden 1. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: adım 3, 2 resimden 2.
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Wireless Card Replacement, Wireless Card: adım 4, 1 resimden 1.
    • Remove the 4mm Phillips #0 screw securing the wireless adapter to the main circuit board.
  5. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: adım 5, 1 resimden 1.
    • Unplug the Wireless adapter from the main circuit board by giving the adapter light pressure and sliding it out of its port.
  6. Acer Chromebook CB3-431-C5EX Wireless Card Replacement: adım 6, 1 resimden 1.
    • Detach the two cables from the Adapter by pulling directly up on them, and then remove the adapter.
    • Note that the black cable is already detached in this photo to show what it looks like with the cables removed.
    • Be sure to note the original locations of the black and white cables when installing the new wireless adapter.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Holden Kurfess
358 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G3
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 1,459
