Ana içeriğe geç
Acer Chromebook CB315-3HT-C3FQ Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB315-3HT-C3FQ Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the Chromebook over so the bottom is facing up.
  2. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: adım 2, 1 resimden 1.
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
  3. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: adım 3, 2 resimden 1. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: adım 3, 2 resimden 2.
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
  4. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: adım 4, 2 resimden 1. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: adım 4, 2 resimden 2.
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
  5. Acer Chromebook CB315-3HT-C3FQ Battery Replacement, Battery: adım 5, 2 resimden 1. Acer Chromebook CB315-3HT-C3FQ Battery Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the thermal tape that covers the wires connecting the battery to the motherboard.
    • Move the thermal tape to the side so you can put it back on afterwards.
  6. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: adım 6, 2 resimden 1. Acer Chromebook CB315-3HT-C3FQ Battery Replacement: adım 6, 2 resimden 2.
    • Unplug the bundle of wires that connect the battery to the motherboard.
    • Remove the battery from the laptop.
Sonuç
brocha2
135 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Santin Spring 2024 UMass Dartmouth, Team 1-5, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G5
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 35
Her zaman: 248
