Ana içeriğe geç
Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the Chromebook over so the bottom is facing up.
  2. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: adım 2, 1 resimden 1.
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
  3. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: adım 3, 2 resimden 1. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: adım 3, 2 resimden 2.
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
  4. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: adım 4, 2 resimden 1. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: adım 4, 2 resimden 2.
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
  5. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement, Daughterboard: adım 5, 1 resimden 1.
    • Detach the four cable connectors from the daughterboard.
  6. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: adım 6, 1 resimden 1.
    • Remove the two silver screws with a Phillips #1 screwdriver.
    • Remove the two black screws with a Phillips #1 screwdriver.
  7. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: adım 7, 2 resimden 1. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: adım 7, 2 resimden 2.
    • Lift up the metal hinge.
  8. Acer Chromebook CB315-3HT-C3FQ Daughterboard Replacement: adım 8, 1 resimden 1.
    • Remove the daughterboard from the laptop.
Sonuç
Ethan Sylvia
351 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-5, Santin Spring 2024 UMass Dartmouth, Team 1-5, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G5
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 171
