Giriş
If your Acer Chromebook CB5-132T-C8ZW will not turn on or has a burning odor, your motherboard may be faulty and needs to be replaced.
The motherboard is one of the main components of your Chromebook. It allows all the computer hardware to communicate with one another. A non-functioning motherboard will make your Chromebook run poorly. You may smell a burning odor, see visibly broken parts, the screen may be frozen, or you may get the “blue screen of death.”
Before beginning, make sure the Chromebook is disconnected from any external power source; then press and hold the power button for at least five seconds prior to dismantling in order to release any stored energy that could potentially be harmful.
Neye ihtiyacın var
Remove eleven 7.2 mm screws from the bottom of the Chromebook using a JIS #1 screwdriver.
Remove the six tabs connected to the motherboard.
Flip up the white tabs on the connectors, and pull out blue connective strips.
Pull up on the black connector on top right corner of the motherboard.
Bir başkası bu kılavuzu tamamladı.
