Ana içeriğe geç
Acer Chromebook CB5-312T-K 8Z9 Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: adım 1, 2 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: adım 1, 2 resimden 2.
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: adım 2, 1 resimden 1.
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: adım 3, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: adım 3, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: adım 4, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: adım 4, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: adım 4, 3 resimden 3.
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
Sonuç
Alonso
224 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 1,474
