Ana içeriğe geç
Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: adım 1, 2 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: adım 1, 2 resimden 2.
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 2, 1 resimden 1.
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Battery: adım 3, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Battery: adım 3, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Battery: adım 3, 3 resimden 3.
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 4, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 4, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 4, 3 resimden 3.
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
  5. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Speaker: adım 5, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Speaker: adım 5, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Speaker: adım 5, 3 resimden 3.
    • Begin by locating the speakers.
    • Once you have found where the speakers are, direct your attention to the speaker to the left of the mouse pad.
    • Grab your tweezers and begin disconnecting the wire that connects the speakers to the circuit board on the upper left corner.
  6. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 6, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 6, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 6, 3 resimden 3.
    • Locate where the mouse pad would be, this should be relatively easy as it will be right in between the two speakers.
    • Start peeling off the black tape that is covering the speaker wires.
    • Fold back the cables that are on top of the wires for easy removal of the speakers.
  7. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 7, 3 resimden 1. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 7, 3 resimden 2. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: adım 7, 3 resimden 3.
    • Direct your attention back to the speaker that you were first working with in step 5.
    • Start by pulling up on the speaker, it should simply come right out.
    • Repeat this for the right speaker.
    • Once the two speakers are removed, unhook the wires from any clips that may be holding it to the computer.
Sonuç
Kyle
125 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 444
