Ana içeriğe geç
Acer Chromebook CB5-571-C5XU Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: adım 1, 2 resimden 1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: adım 2, 2 resimden 1. Acer Chromebook CB5-571-C5XU Battery Replacement: adım 2, 2 resimden 2.
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: adım 4, 1 resimden 1.
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: adım 5, 1 resimden 1.
    • Gently lift the battery out and remove it from the laptop casing.
Sonuç
To reassemble your device, follow these guidelines in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Kenneth Bowers
1.381 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 UMass Dartmouth, Team S1-G1, Valliere Fall 2018 üyesi
UMASSD-VALLIERE-F18S1G1
4 Üyeler
19 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 824
