Ana içeriğe geç
Acer Chromebook CB5-571-C5XU Bottom Case Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB5-571-C5XU Bottom Case Replacement, Bottom Case: adım 1, 2 resimden 1. Acer Chromebook CB5-571-C5XU Bottom Case Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Bottom Case Replacement: adım 2, 2 resimden 1. Acer Chromebook CB5-571-C5XU Bottom Case Replacement: adım 2, 2 resimden 2.
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Erin Moffatt
282 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 UMass Dartmouth, Team S6-G1, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 204
