Ana içeriğe geç
Acer Chromebook CB5-571-C5XU Solid State Drive Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: adım 1, 2 resimden 1. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: adım 2, 2 resimden 1. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: adım 2, 2 resimden 2.
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement, Solid State Drive: adım 3, 1 resimden 1.
    • Using the Phillips #0 Screwdriver, unscrew the single screw holding the Solid State Drive in place.
  4. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: adım 4, 1 resimden 1.
    • Gently lift the Solid State Drive upwards at an angle until it stops.
    • Be careful not to lift the Solid State Drive past where it stops, or you will risk breaking the hardware.
  5. Acer Chromebook CB5-571-C5XU Solid State Drive Replacement: adım 5, 1 resimden 1.
    • Pull the Solid State Drive out from the socket in the direction of the angle at which it was resting.
    • The Solid State Drive should pull out with little effort. If it is resisting, do not pull harder, as this risks damage to the part.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Flint
273 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 UMass Dartmouth, Team S6-G1, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 377
