Ana içeriğe geç
Acer Chromebook CB5-571-C5XU Speaker Replacement
Neye ihtiyacın var
  1. Acer Chromebook CB5-571-C5XU Speaker Replacement, Bottom Case: adım 1, 2 resimden 1. Acer Chromebook CB5-571-C5XU Speaker Replacement, Bottom Case: adım 1, 2 resimden 2.
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Speaker Replacement: adım 2, 2 resimden 1. Acer Chromebook CB5-571-C5XU Speaker Replacement: adım 2, 2 resimden 2.
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Speaker Replacement, Battery: adım 3, 1 resimden 1.
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Speaker Replacement: adım 4, 1 resimden 1.
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Speaker Replacement: adım 5, 1 resimden 1.
    • Gently lift the battery out and remove it from the laptop casing.
  6. Acer Chromebook CB5-571-C5XU Speaker Replacement, Speakers: adım 6, 2 resimden 1. Acer Chromebook CB5-571-C5XU Speaker Replacement, Speakers: adım 6, 2 resimden 2.
    • Use the plastic pry tool to unlatch the two tabs on either side of the black ribbon.
    • Gently slide the black ribbon out from its socket and under the white ribbon.
  7. Acer Chromebook CB5-571-C5XU Speaker Replacement: adım 7, 1 resimden 1.
    • Carefully remove the smaller black ribbon from the motherboard using the opening tool.
    • Be careful when prying the connector loose, its small size can make it difficult to grasp a corner of the connector.
  8. Acer Chromebook CB5-571-C5XU Speaker Replacement: adım 8, 1 resimden 1.
    • Weave the black wire connecting the two speakers out of the small metal hooks.
    • It might be helpful to take a picture of how the wire is wrapped around the hooks, as this layout is important when the wire is put back.
  9. Acer Chromebook CB5-571-C5XU Speaker Replacement: adım 9, 1 resimden 1.
    • Simply lift upwards on both speakers, and they will remove from their position.
Sonuç
Bir başkası bu kılavuzu tamamladı.
️Gaetan Charles
119 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 UMass Dartmouth, Team S6-G1, Rockett Fall 2017 üyesi
UMASSD-ROCKETT-F17S6G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 157
