Giriş
This guide will show you how to remove the Acer Chromebook CP5-471-C0EX fan for replacement or repair. The fan and cooling system is an integral part of the computer. A poorly functioning fan may cause the system to slow down or cease entirely by overheating.
Make sure to power down your device and disconnect from any power sources before you begin.
Neye ihtiyacın var
Carefully detach the ribbon cable connecting the battery and the motherboard.
Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
Bir başkası bu kılavuzu tamamladı.
