Ana içeriğe geç
Acer Chromebook CP5-471-C0EX Motherboard Replacement
Neye ihtiyacın var
  1. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Battery: adım 1, 2 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  2. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 2, 1 resimden 1.
    • Use your hands to lift the battery out of the device.
  3. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: adım 3, 3 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: adım 3, 3 resimden 2. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: adım 3, 3 resimden 3.
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  4. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 4, 3 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 4, 3 resimden 2. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 4, 3 resimden 3.
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  5. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 5, 2 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  6. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 6, 2 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 6, 2 resimden 2.
    • Carefully remove the trackpad from the device.
  7. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Wi-Fi Card: adım 7, 1 resimden 1.
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  8. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 8, 2 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the single 3 mm screw using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 9, 1 resimden 1.
    • Gently pull the wireless card away from the motherboard to remove it.
  10. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Fan: adım 10, 2 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Fan: adım 10, 2 resimden 2.
  11. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 11, 3 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 11, 3 resimden 2. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 11, 3 resimden 3.
    • Unwind the Wi-Fi card wires from the side of the fan.
    • The wires need to be pulled down and around the first hook, as seen in image two.
    • Pull the black and white cables under the second hook and away from the fan.
  12. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 12, 3 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 12, 3 resimden 2. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 12, 3 resimden 3.
    • Pull wires so they are out the way.
    • Loosen the six screws from the fan and heat sink.
    • The two screws closest to the fan cannot be removed from the fan, but will still loosen from the case.
  13. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 13, 3 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 13, 3 resimden 2. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 13, 3 resimden 3.
    • Gently lift the fan out of the case, but do not remove it fully; there is still one more cable attached.
    • Pull the cable out of its socket on the motherboard.
    • Remove the fan from the laptop.
  14. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Motherboard: adım 14, 2 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Motherboard: adım 14, 2 resimden 2.
    • Push on the sides of the connector to gently disconnect the speaker cable from the motherboard.
  15. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 15, 3 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 15, 3 resimden 2. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 15, 3 resimden 3.
    • Use an iFixit opening tool to pry the display cable up from the motherboard.
  16. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 16, 2 resimden 1. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 16, 2 resimden 2.
    • Remove seven 3 mm screws from the motherboard using a Phillips #1 screwdriver.
  17. Acer Chromebook CP5-471-C0EX Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the motherboard from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Naomi Salas
244 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Saknee Spring 2022 Gateway, Team 1-1, Saknee Spring 2022 üyesi
GCC-SAKNEE-S22S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 347
