Ana içeriğe geç
Acer Chromebook CP5-471-C0EX Trackpad Replacement
Neye ihtiyacın var
  1. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: adım 1, 2 resimden 1. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: adım 1, 2 resimden 2.
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 2, 3 resimden 1. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 2, 3 resimden 2. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 2, 3 resimden 3.
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 3, 2 resimden 1. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 3, 2 resimden 2.
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: adım 4, 2 resimden 1. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: adım 4, 2 resimden 2.
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 5, 1 resimden 1.
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: adım 6, 3 resimden 1. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: adım 6, 3 resimden 2. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: adım 6, 3 resimden 3.
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  7. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 7, 3 resimden 1. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 7, 3 resimden 2. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 7, 3 resimden 3.
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  8. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 8, 2 resimden 1. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 8, 2 resimden 2.
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 9, 2 resimden 1. Acer Chromebook CP5-471-C0EX Trackpad Replacement: adım 9, 2 resimden 2.
    • Carefully remove the trackpad from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trestin Bachtiger
239 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Saknee Spring 2022 Gateway, Team 1-1, Saknee Spring 2022 üyesi
GCC-SAKNEE-S22S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 105
