Ana içeriğe geç
Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Back Cover: adım 1, 2 resimden 1. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Back Cover: adım 1, 2 resimden 2.
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: adım 2, 3 resimden 1. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: adım 2, 3 resimden 2. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: adım 2, 3 resimden 3.
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: adım 3, 2 resimden 1. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: adım 3, 2 resimden 2.
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Battery: adım 4, 2 resimden 1. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Battery: adım 4, 2 resimden 2.
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Wi-Fi Card: adım 6, 1 resimden 1.
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  7. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: adım 7, 2 resimden 1. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: adım 7, 2 resimden 2.
    • Remove the single 3 mm screw using a Phillips #1 screwdriver.
  8. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: adım 8, 1 resimden 1.
    • Gently pull the wireless card away from the motherboard to remove it.
Sonuç
Aida mohamed
186 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Saknee Spring 2022 Gateway, Team 1-1, Saknee Spring 2022 üyesi
GCC-SAKNEE-S22S1G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 134
