Giriş
This guide will show you how to replace the Wi-Fi card in your Acer Chromebook CP5-471-C0EX laptop. If you’re having trouble connecting to Wi-Fi or experience frequently dropped connections, you may have a faulty Wi-Fi card. The laptop will also fail to detect any wireless connection even when such networks are available. The operating system may also fail to recognize the Wi-Fi card. Replacing or re-setting the wireless card may fix it.
The Wi-Fi card provides the laptop with a dedicated, full-time connection to a network.
Make sure to power down your device and disconnect from any power sources before you begin.
Neye ihtiyacın var
Carefully detach the ribbon cable connecting the battery and the motherboard.
Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
