Ana içeriğe geç
Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement, Battery: adım 1, 2 resimden 1. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop over so that the backside is facing up.
    • Use a Phillips #0 screwdriver to remove nine screws along the perimeter of the back case.
    • Use an opening tool to pry the case around the perimeter and gently release the clips attaching the back case to the front.
    • Lift the back case off of the Chromebook.
  2. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: adım 2, 2 resimden 1. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove two screws on either side of the battery.
  3. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: adım 3, 2 resimden 1. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: adım 3, 2 resimden 2.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap. Then, you can safely pull the cable out to disconnect the battery from the motherboard.
  4. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: adım 4, 2 resimden 1. Acer Chromebook R 11 CB5-132T-C9KK Battery Replacement: adım 4, 2 resimden 2.
    • Remove the battery from the Chromebook.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Supplee
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 181
