Ana içeriğe geç
Acer Chromebook R11 C738T-C44Z Motherboard Replacement
Neye ihtiyacın var
  1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: adım 2, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Battery: adım 2, 2 resimden 2.
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 4, 1 resimden 1.
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: adım 5, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Wireless Card: adım 5, 2 resimden 2.
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  6. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  7. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 7, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 7, 2 resimden 2.
    • Carefully slide the wireless card out of its socket from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: adım 8, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: adım 8, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Motherboard Replacement, Motherboard: adım 8, 3 resimden 3.
    • Disconnect the LED board ribbon by pulling it out gently.
    • Disconnect the speaker cable.
  9. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 9, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 9, 2 resimden 2.
    • Disconnect the keyboard ribbon.
    • Slide it out gently to not rip it.
  10. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 10, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 10, 2 resimden 2.
    • Disconnect the daughterboard ribbon by flipping up the white tab and pulling it out from the motherboard.
  11. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 11, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 11, 2 resimden 2.
    • Disconnect the touchpad ribbon by lifting up the tab and pulling it out.
  12. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 12, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 12, 2 resimden 2.
    • Disconnect the sensor cable by pulling it out.
  13. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 13, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 13, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 13, 3 resimden 3.
    • Disconnect the LCD cable by pinching it and lifting it off the motherboard.
  14. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 14, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 14, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws that hold the hinge down.
  15. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 15, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 15, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 15, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the motherboard.
  16. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 16, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 16, 2 resimden 2.
    • Slide the opening tool underneath the hinge latch to lift it up.
    • This is to free the motherboard.
  17. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 17, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Motherboard Replacement: adım 17, 2 resimden 2.
    • Grab the motherboard securely to lift and remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Connie Hernandez
517 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 478
