Ana içeriğe geç
Acer Chromebook R11 C738T-C44Z Speakers Replacement
Neye ihtiyacın var
  1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: adım 1, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: adım 1, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: adım 1, 3 resimden 3.
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: adım 2, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: adım 2, 2 resimden 2.
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 3, 1 resimden 1.
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 4, 1 resimden 1.
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: adım 5, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: adım 5, 2 resimden 2.
    • Gently remove the LED Board Ribbon connected to the mother board.
  6. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 6, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 6, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 6, 3 resimden 3.
    • Gently pry up speaker up using a spudger or opening tool to remove it.
    • It has an adhesive, so you might have to use some force.
    • Screwdrivers should not be used as prying tools and could cause damage to delicate components.
    • Repeat the same process for the other speaker.
  7. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 7, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 7, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 7, 3 resimden 3.
    • Use the opening tool to unplug the speaker cable from the motherboard.
    • Disconnect the keyboard ribbon cable from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 8, 1 resimden 1.
    • Using the opening tool to unlock and disconnect the touchpad cable.
  9. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 9, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 9, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Speakers Replacement: adım 9, 3 resimden 3.
    • Gently lift the speakers up and remove the cable from the system.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Connie Hernandez
517 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 104
