Ana içeriğe geç
Acer Chromebook R11 C738T-C44Z Touchpad Replacement
Neye ihtiyacın var
  1. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: adım 1, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: adım 1, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: adım 1, 3 resimden 3.
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: adım 2, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: adım 2, 2 resimden 2.
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: adım 3, 1 resimden 1.
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: adım 4, 1 resimden 1.
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: adım 5, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: adım 5, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: adım 5, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the touchpad.
    • Lift up the tab for the cable cord.
    • Pull out the touchpad connector.
  6. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: adım 6, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: adım 6, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: adım 6, 3 resimden 3.
    • Pull the left piece of tape up by prying it up with your fingers or with the screwdriver.
    • Be gentle to not rip the tape.
    • Next, pull up the other piece of tape.
    • Remove the touchpad.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Connie Hernandez
517 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G4
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Thank you, Connie Fernandez. ~Super
Super - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 309
