Ana içeriğe geç
Acer Chromebook R11 C738T-C44Z Wireless Card Replacement
Neye ihtiyacın var
  1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: adım 1, 3 resimden 1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: adım 1, 3 resimden 2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: adım 1, 3 resimden 3.
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: adım 2, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: adım 2, 2 resimden 2.
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  3. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  4. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: adım 4, 2 resimden 1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: adım 4, 2 resimden 2.
    • Carefully slide the wireless card out of its socket from the motherboard.
Sonuç
Connie Hernandez
517 İtibar
4 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Saknee Fall 2021 Gateway, Team 1-4, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 314
