Ana içeriğe geç
Acer Chromebook R11 CB5-132T-C1LK Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: adım 2, 1 resimden 1.
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the two 4.5 mm Phillips screws located at the sides of the battery.
  4. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: adım 4, 2 resimden 1. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: adım 4, 2 resimden 2.
    • Grip the battery connection using two plastic opening tools.
    • Carefully but firmly, pry the connector from its socket by pulling it towards the battery.
    • When reconnecting the battery to the motherboard, place the red wires closer to the edge of the device and the black wires towards the center.
  5. Acer Chromebook R11 CB5-132T-C1LK Battery Replacement: adım 5, 1 resimden 1.
    • Lift the battery out by pulling upward.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alan Shan
382 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 4,646
