Ana içeriğe geç
Acer Chromebook R11 CB5-132T-C1LK Camera Replacement
Neye ihtiyacın var
  1. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement, Camera: adım 1, 2 resimden 1. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement, Camera: adım 1, 2 resimden 2.
    • Insert the metal spudger into the groove on the edge of the screen.
    • Carefully slide the spudger from one corner to another.
    • When there is room for a finger, remove the screen by gently lifting it out of the computer.
  2. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement: adım 2, 1 resimden 1.
    • Using a heavy duty spudger, lift the camera off the screen base.
    • The camera will be connected to the base with an adhesive.
  3. Acer Chromebook R11 CB5-132T-C1LK Camera Replacement: adım 3, 1 resimden 1.
    • Unplug the camera from its port.
Sonuç
Elizabeth Crisologo
278 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G2
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Hi Elizabeh, can you do a tutorial to change the mic on this chromebook?
There was a production batch of this chromebook that had a problem with the mic. So a lot of people could benefit from this.
Cheers!
Álvaro Guzmán Parrochia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 503
