Ana içeriğe geç
Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement
Neye ihtiyacın var
  1. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, Bottom Panel: adım 1, 1 resimden 1.
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: adım 2, 1 resimden 1.
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: adım 3, 2 resimden 1. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the flat end of the spudger to lift the retaining flap on the LED board ZIF connector.
    • Pull the ribbon cable from the ZIF connector using tweezers.
  4. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: adım 4, 1 resimden 1.
    • Remove the 4.5 mm Phillips screw.
    • There is a magnet near the LED chip that might attract the screw.
  5. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: adım 5, 1 resimden 1.
    • Use tweezers to remove the LED board.
Sonuç
Alan Shan
382 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G2, Livingston Spring 2017 Cal Poly, Team S23-G2, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 954
