Ana içeriğe geç
Acer Chromebook R11 Speakers Replacement
Neye ihtiyacın var
  1. Acer Chromebook R11 Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • The back cover of the R11 is held into place using 11 screws.
    • To remove, use a screwdriver appropriate for a JIS 1 screw.
  2. Acer Chromebook R11 Speakers Replacement: adım 2, 1 resimden 1.
    • Battery is located in the bottom half of the computer.
    • Unscrew the two screws holding the battery in place. There is one on each side of the battery.
  3. Acer Chromebook R11 Speakers Replacement: adım 3, 1 resimden 1.
    • Slide out the ribbon that is connecting the battery to the motherboard.
    • There are 7 wires leading to it, and each is a different color of the rainbow.
    • Disconnect the keyboard ribbon located at bottom center of motherboard.
  4. Acer Chromebook R11 Speakers Replacement: adım 4, 1 resimden 1.
    • Remove the battery by pulling upwards.
  5. Acer Chromebook R11 Speakers Replacement, Speakers: adım 5, 2 resimden 1. Acer Chromebook R11 Speakers Replacement, Speakers: adım 5, 2 resimden 2.
    • Slide out black ribbons connecting speakers to motherboard
    • Connected on lower left-hand side of motherboard
    • When removing wires, remove gently with respect to metal clips along wires that are holding them in place.
    • Slide out white ribbon connecting keyboard to motherboard
  6. Acer Chromebook R11 Speakers Replacement: adım 6, 1 resimden 1.
    • Gently pull speakers upwards
    • Adhesive is below it
Sonuç
Bir başkası bu kılavuzu tamamladı.
Victoria May
119 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Kass Spring 2017 USF Tampa, Team 1-2, Kass Spring 2017 üyesi
USFT-KASS-S17S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 480
