Ana içeriğe geç
Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement
Neye ihtiyacın var
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Back Cover: adım 1, 2 resimden 1. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: adım 2, 3 resimden 1. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: adım 2, 3 resimden 2. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: adım 2, 3 resimden 3.
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Battery: adım 3, 3 resimden 1. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Battery: adım 3, 3 resimden 2. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Remove the ribbon cable by pulling the plastic connector that is connected to the motherboard out.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the laptop by hand.
Sonuç
Evan Costa
503 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 UMass Dartmouth, Team S4-G1, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G1
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 2,589
