Ana içeriğe geç
Acer Chromebook Spin 15 CP315-1H-P1K8 USB-C Port Replacement
Neye ihtiyacın var
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 USB-C Port Replacement, Back Cover: adım 1, 2 resimden 1. Acer Chromebook Spin 15 CP315-1H-P1K8 USB-C Port Replacement, Back Cover: adım 1, 2 resimden 2.
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 USB-C Port Replacement: adım 2, 3 resimden 1. Acer Chromebook Spin 15 CP315-1H-P1K8 USB-C Port Replacement: adım 2, 3 resimden 2. Acer Chromebook Spin 15 CP315-1H-P1K8 USB-C Port Replacement: adım 2, 3 resimden 3.
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 USB-C Port Replacement, USB-C Port: adım 3, 1 resimden 1.
    • Remove the single 3mm Phillips #1 screw from the circuit board.
    • Remove the two ribbon cables from the circuit board.
    • Remove the USB-C port from the laptop.
Sonuç
Devyn Perry
113 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 UMass Dartmouth, Team S4-G1, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G1
3 Üyeler
5 adet Kılavuz yazıldı
5 Yorum
I did all of this (thank you!) and still the Chromebook won’t turn back on again. It’d drained down completely by the time the USB-C port stopped working originally. Any tips?
Mary Beth Quirk - Yanıt
Try looking at the battery replacement guide, it may be an issue with the battery, but if worst comes to worst you may have to take it somewhere to be looked at
Evan Costa -
By drained down, do you mean the battery ran out of charge, cause if that’s the cause it’s a battery issue rather than a USB-C issue
Evan Costa - Yanıt
How does one remove the USB-C port once they have removed the ribbon cables? Is there a separate guide that focuses simply on this step?
Kristen Ritterbush - Yanıt
The USB-C port is held in by a screw or two if I remember right, undo those and then you should be able to get the port out of the case. Hope that helps, unfortunately this guide was written as part of a college project and I no longer have access to the computer to look at and give advice on how to make any progress after this point.
Evan Costa -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 2,650
