Ana içeriğe geç
Acer Chromebook cb3-532-c47c Display Assembly Replacement
Neye ihtiyacın var
  1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: adım 1, 2 resimden 1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Back Panel: adım 1, 2 resimden 2.
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Display Assembly Replacement: adım 2, 2 resimden 1. Acer Chromebook cb3-532-c47c Display Assembly Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the battery cable: adım 3, 1 resimden 1.
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: adım 4, 2 resimden 1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Unplug the WiFi Antenna Connectors: adım 4, 2 resimden 2.
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: adım 5, 2 resimden 1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the Black WiFi Wire: adım 5, 2 resimden 2.
    • Deroute the black wifi wire from its slot in the palm rest.
  6. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: adım 6, 2 resimden 1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Deroute the White WiFi Wire: adım 6, 2 resimden 2.
    • Deroute the white wifi wire from the slot in the palm rest.
  7. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: adım 7, 3 resimden 1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: adım 7, 3 resimden 2. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Disconnect the Display Cable: adım 7, 3 resimden 3.
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  8. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Right Hinge Screws: adım 8, 1 resimden 1.
    • Remove the two screws from the right hinge.
  9. Acer Chromebook cb3-532-c47c Display Assembly Replacement: adım 9, 2 resimden 1. Acer Chromebook cb3-532-c47c Display Assembly Replacement: adım 9, 2 resimden 2.
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  10. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove Left Hinge Screws: adım 10, 1 resimden 1.
    • Remove the two screws from the left hinge.
  11. Acer Chromebook cb3-532-c47c Display Assembly Replacement: adım 11, 2 resimden 1. Acer Chromebook cb3-532-c47c Display Assembly Replacement: adım 11, 2 resimden 2.
  12. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: adım 12, 3 resimden 1. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: adım 12, 3 resimden 2. Acer Chromebook cb3-532-c47c Display Assembly Replacement, Remove the display assembly: adım 12, 3 resimden 3.
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jerry Wheeler
61.046 İtibar
71 adet Kılavuz yazıldı
Ekip
Oregonians Oregonians üyesi
Community
8 Üyeler
183 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 323
