Ana içeriğe geç
Acer Chromebook cb3-532-c47c I/O Board Replacement
Neye ihtiyacın var
  1. Acer Chromebook cb3-532-c47c I/O Board Replacement, Back Panel: adım 1, 2 resimden 1. Acer Chromebook cb3-532-c47c I/O Board Replacement, Back Panel: adım 1, 2 resimden 2.
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c I/O Board Replacement: adım 2, 2 resimden 1. Acer Chromebook cb3-532-c47c I/O Board Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the battery cable: adım 3, 1 resimden 1.
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove Right Hinge Screws: adım 4, 1 resimden 1.
    • Remove the two screws from the right hinge.
  5. Acer Chromebook cb3-532-c47c I/O Board Replacement: adım 5, 2 resimden 1. Acer Chromebook cb3-532-c47c I/O Board Replacement: adım 5, 2 resimden 2.
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  6. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the LED Cable: adım 6, 2 resimden 1. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the LED Cable: adım 6, 2 resimden 2.
    • Flip up the latch on the cable going from the I/O board to the LED board.
  7. Acer Chromebook cb3-532-c47c I/O Board Replacement: adım 7, 2 resimden 1. Acer Chromebook cb3-532-c47c I/O Board Replacement: adım 7, 2 resimden 2.
    • Grasp the ribbon cable and pull it straight out to the right.
  8. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the Motherboard Cable: adım 8, 2 resimden 1. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the Motherboard Cable: adım 8, 2 resimden 2.
    • Flip up the latch on the cable from the I/O board to the motherboard.
  9. Acer Chromebook cb3-532-c47c I/O Board Replacement: adım 9, 2 resimden 1. Acer Chromebook cb3-532-c47c I/O Board Replacement: adım 9, 2 resimden 2.
    • Grasp the ribbon cable by the blue plastic reinforcement and pull the cable straight out to the right.
  10. Acer Chromebook cb3-532-c47c I/O Board Replacement, Remove the Retaining Screw: adım 10, 1 resimden 1.
    • Remove the single screw securing the I/O board.
  11. Acer Chromebook cb3-532-c47c I/O Board Replacement: adım 11, 1 resimden 1.
    • Remove the I/O board.
    • When reinstalling, be sure the hinge goes above the I/O board, not below it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jerry Wheeler
72.398 İtibar
71 adet Kılavuz yazıldı
Ekip
Oregonians Oregonians üyesi
Community
8 Üyeler
191 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 253
