Ana içeriğe geç
Acer Chromebook cb3-532-c47c LED Board Replacement
Neye ihtiyacın var
  1. Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: adım 1, 2 resimden 1. Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: adım 1, 2 resimden 2.
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c LED Board Replacement: adım 2, 2 resimden 1. Acer Chromebook cb3-532-c47c LED Board Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the battery cable: adım 3, 1 resimden 1.
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: adım 4, 2 resimden 1. Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: adım 4, 2 resimden 2.
    • Flip the retaining latch up with a spudger.
  5. Acer Chromebook cb3-532-c47c LED Board Replacement: adım 5, 2 resimden 1. Acer Chromebook cb3-532-c47c LED Board Replacement: adım 5, 2 resimden 2.
    • Pull the cable straight out away from the front of the computer.
  6. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: adım 6, 3 resimden 1. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: adım 6, 3 resimden 2. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: adım 6, 3 resimden 3.
    • Remove the single retaining screw securing the LED board.
    • Remove the board.
    • When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jerry Wheeler
72.398 İtibar
71 adet Kılavuz yazıldı
Ekip
Oregonians Oregonians üyesi
Community
8 Üyeler
191 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 92
