Ana içeriğe geç
Acer Chromebook cb3-532-c47c WiFi Card Replacement
Neye ihtiyacın var
  1. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Back Panel: adım 1, 2 resimden 1. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Back Panel: adım 1, 2 resimden 2.
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c WiFi Card Replacement: adım 2, 2 resimden 1. Acer Chromebook cb3-532-c47c WiFi Card Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Remove the battery cable: adım 3, 1 resimden 1.
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Unplug the WiFi Antenna Connectors: adım 4, 2 resimden 1. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Unplug the WiFi Antenna Connectors: adım 4, 2 resimden 2.
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c WiFi Card Replacement, WiFi Card: adım 5, 3 resimden 1. Acer Chromebook cb3-532-c47c WiFi Card Replacement, WiFi Card: adım 5, 3 resimden 2. Acer Chromebook cb3-532-c47c WiFi Card Replacement, WiFi Card: adım 5, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
Sonuç
Jerry Wheeler
72.398 İtibar
71 adet Kılavuz yazıldı
Ekip
Oregonians Oregonians üyesi
Community
8 Üyeler
191 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 26
Her zaman: 205
