Ana içeriğe geç
Acer E5-571-54FL CPU Replacement
Neye ihtiyacın var
  1. Acer E5-571-54FL CPU Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is shut down.
    • Flip the laptop upside down with the battery facing towards you.
  2. Acer E5-571-54FL CPU Replacement: adım 2, 1 resimden 1.
    • Place the pointed end of a spudger into the battery lock and slide it to the left until you hear the battery release.
  3. Acer E5-571-54FL CPU Replacement: adım 3, 1 resimden 1.
    • Pull the battery towards you to remove it from the laptop.
  4. Acer E5-571-54FL CPU Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer E5-571-54FL CPU Replacement: adım 5, 3 resimden 1. Acer E5-571-54FL CPU Replacement: adım 5, 3 resimden 2. Acer E5-571-54FL CPU Replacement: adım 5, 3 resimden 3.
    • Move around the edge with metal spudger and carefully pry apart the clips holding the keyboard in place.
    • Be careful not to break the plastic clips and do not remove the keyboard yet.
  6. Acer E5-571-54FL CPU Replacement: adım 6, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 6, 2 resimden 2.
    • Carefully detach the three ZIF ribbons connected to the motherboard by flipping up the white hinge.
    • Lift up on the keyboard and the whole top should come right off, including the touchpad.
  7. Acer E5-571-54FL CPU Replacement, Cooling Fan: adım 7, 3 resimden 1. Acer E5-571-54FL CPU Replacement, Cooling Fan: adım 7, 3 resimden 2. Acer E5-571-54FL CPU Replacement, Cooling Fan: adım 7, 3 resimden 3.
    • The CPU Cooling Fan is in the upper left corner of the laptop.
    • Using a #0 Phillips screwdriver, remove the two 4.5mm screws holding the fan to the case.
  8. Acer E5-571-54FL CPU Replacement: adım 8, 3 resimden 1. Acer E5-571-54FL CPU Replacement: adım 8, 3 resimden 2. Acer E5-571-54FL CPU Replacement: adım 8, 3 resimden 3.
    • Place the tips of the ESD safe pointed tweezers between the plug and socket of the fan connection.
    • Gently push left to disconnect the fan plug.
    • Move the fan connector and wires free of the motherboard and WiFi card.
  9. Acer E5-571-54FL CPU Replacement: adım 9, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 9, 2 resimden 2.
    • Lift the curved end of the fan about 30 degrees.
    • Remove the fan by moving your hand up and to the right until it is clear of the case.
    • If you feel resistance, check to be sure the fan connector and wires are not stuck under the motherboard or WiFi card.
  10. Acer E5-571-54FL CPU Replacement, WiFi Card: adım 10, 2 resimden 1. Acer E5-571-54FL CPU Replacement, WiFi Card: adım 10, 2 resimden 2.
    • The WiFi card is just below the fan with a white coaxial cable and a black coaxial cable attached.
    • Using ESD safe blunt nose metal tweezers, grab just behind the brass connection on the white coaxial cable attached to the WiFi card.
    • Carefully lift up and forward to disconnect the wire.
    • Repeat both procedure one and two to remove the black coaxial cable.
  11. Acer E5-571-54FL CPU Replacement: adım 11, 1 resimden 1.
    • Using a #0 Phillips screwdriver, remove the 3mm screw from the upper left corner of the WiFi card.
    • The edge of WiFi card will lift up as the screw is removed.
  12. Acer E5-571-54FL CPU Replacement: adım 12, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 12, 2 resimden 2.
    • Grab the upper left corner of the WiFi card with your fingers.
    • Gently pull the WiFi card away from the socket.
  13. Acer E5-571-54FL CPU Replacement, Hard drive: adım 13, 2 resimden 1. Acer E5-571-54FL CPU Replacement, Hard drive: adım 13, 2 resimden 2.
    • The hard drive and carriage are at the lower right of the laptop.
    • Using the plastic opening tool, carefully lift up on the black locking tab of the ZIF connector to release the USB port ribbon cable.
    • Move the USB port ribbon cable out of the way
  14. Acer E5-571-54FL CPU Replacement: adım 14, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 14, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the two 4mm screws securing the hard drive carriage in place.
  15. Acer E5-571-54FL CPU Replacement: adım 15, 1 resimden 1.
    • Hold the right side of the laptop in place with your right hand.
    • Put the fingers of your left hand along the top edge of the hard drive carriage.
    • Push the hard drive carriage towards your right hand to disconnect it from the motherboard.
    • This procedure may require more force then other procedures.
  16. Acer E5-571-54FL CPU Replacement: adım 16, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 16, 2 resimden 2.
    • Lift up on the edge of the hard drive carriage closest to your body to remove the carriage.
    • If doing the motherboard replacement guide, skip the next step.
  17. Acer E5-571-54FL CPU Replacement: adım 17, 3 resimden 1. Acer E5-571-54FL CPU Replacement: adım 17, 3 resimden 2. Acer E5-571-54FL CPU Replacement: adım 17, 3 resimden 3.
    • There are two 3mm Phillips screws holding the hard drive into the carriage. One on either side of the carriage.
    • Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
    • Using a #0 Phillips screwdriver, remove the 3mm screw to release the side of the hard drive from the carriage.
    • Repeat the two previous procedures to remove the second 3mm Phillips screw freeing the hard drive from the carriage.
  18. Acer E5-571-54FL CPU Replacement, Motherboard: adım 18, 2 resimden 1. Acer E5-571-54FL CPU Replacement, Motherboard: adım 18, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the two 4mm screws and set them aside.
  19. Acer E5-571-54FL CPU Replacement: adım 19, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 19, 2 resimden 2.
    • The three wire speaker connection is centered at the edge of the motherboard closest to your body.
    • Place the tips of the ESD safe pointed tweezers between the plug and socket of the speaker connection.
    • Gently push left to disconnect the speaker plug.
  20. Acer E5-571-54FL CPU Replacement: adım 20, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 20, 2 resimden 2.
    • The screen connection is centered on the motherboard furthest from your body.
    • With your fingernails on each side of the plug, gently push away from your body to disconnect it.
  21. Acer E5-571-54FL CPU Replacement: adım 21, 1 resimden 1.
    • Carefully lift up on the right edge of the motherboard near the hard drive connector.
    • With minimal force, pull the motherboard to the right freeing the ports on the left from the case.
    • Put down the right side and allow the motherboard to rest in the case.
    • There is still one connection to be removed which lies underneath the motherboard.
    • Lift the left side of the motherboard up and turn it over so the ports are now facing right.
  22. Acer E5-571-54FL CPU Replacement: adım 22, 1 resimden 1.
    • Grip the bottom edge of the motherboard closest to your body with your non-dominant hand.
    • Grip the power connection wires with your dominant hand and gently pull away from your body to disconnect.
  23. Acer E5-571-54FL CPU Replacement: adım 23, 1 resimden 1.
    • Lift the motherboard out of the case.
  24. Acer E5-571-54FL CPU Replacement, CPU: adım 24, 1 resimden 1.
    • Make sure the laptop is shut down. Flip the laptop upside down with the battery facing towards you.
  25. Acer E5-571-54FL CPU Replacement: adım 25, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 25, 2 resimden 2.
    • Place the pointed end of a spudger into the battery lock and slide it to the left until you hear the battery release. Pull the battery towards you to remove it from the laptop.
  26. Acer E5-571-54FL CPU Replacement: adım 26, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 26, 2 resimden 2.
    • Insert wisdom here.
  27. Acer E5-571-54FL CPU Replacement: adım 27, 2 resimden 1. Acer E5-571-54FL CPU Replacement: adım 27, 2 resimden 2.
    • Unscrew the outer 6 mm screws on both top and bottom sides of the fan. Detach the power cable by pulling it out. Remove the cooling fan.
  28. Acer E5-571-54FL CPU Replacement: adım 28, 3 resimden 1. Acer E5-571-54FL CPU Replacement: adım 28, 3 resimden 2. Acer E5-571-54FL CPU Replacement: adım 28, 3 resimden 3.
    • Locate the hard drive. There are two 4mm Phillips head screws connecting the hard drive to the motherboard. Unscrew them. Carefully flip the ZIF ribbon out of the way, and remove the hard drive.
  29. Acer E5-571-54FL CPU Replacement: adım 29, 1 resimden 1.
    • Finish unscrewing any screws holding the motherboard down, and remove the motherboard.
  30. Acer E5-571-54FL CPU Replacement: adım 30, 3 resimden 1. Acer E5-571-54FL CPU Replacement: adım 30, 3 resimden 2. Acer E5-571-54FL CPU Replacement: adım 30, 3 resimden 3.
    • Gently unplug both wires connected to the wi-fi card to disconnect it.
Sonuç
Congratulations! You have successfully completed the process of replacing the CPU in your Acer E5-571-54FL laptop. This guide provided step-by-step instructions, guiding you through the disassembly of various components such as the battery, keyboard, cooling fan, WiFi card, hard drive, and motherboard. Carefully following each step ensures a smooth disassembly process.
Remember to exercise caution and use the appropriate tools to avoid damage during the procedure. If you encountered any resistance or difficulties, double-check the connections and components to ensure everything is properly disconnected. Take your time, and don't hesitate to refer back to specific steps if needed.
To reassemble your device, simply follow the instructions in reverse order. Start by reconnecting the motherboard, securing it with screws, and reconnecting any detached components. Be sure to tighten all screws securely but avoid over-tightening. Finally, reattach the battery and power on your Acer E5-571-54FL.
If you found this guide helpful, consider providing feedback or sharing your experience. If you encountered any challenges or have suggestions for improvement, feel free to contribute to the community. Thank you for using this guide, and best of luck with your newly replaced CPU!
Jennifer Hancock
325 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 618
