Ana içeriğe geç
Acer E5-571-54FL Hard drive Replacement
Neye ihtiyacın var
  1. Acer E5-571-54FL Hard drive Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Hard drive Replacement: adım 2, 2 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 2, 2 resimden 2.
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Hard drive Replacement: adım 3, 2 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 3, 2 resimden 2.
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Hard drive Replacement, Keyboard: adım 4, 1 resimden 1.
    • Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
  5. Acer E5-571-54FL Hard drive Replacement: adım 5, 1 resimden 1.
    • Rotate the laptop 180 degrees so that the battery compartment is now furthest away from your body.
  6. Acer E5-571-54FL Hard drive Replacement: adım 6, 1 resimden 1.
    • Turn the laptop over so that you can easily open the screen to a vertical position.
  7. Acer E5-571-54FL Hard drive Replacement: adım 7, 1 resimden 1.
    • Put your fingers under the top of the keyboard assembly directly below the Acer logo.
    • Carefully pull up on the center until you hear the tabs disengage from the bottom.
  8. Acer E5-571-54FL Hard drive Replacement: adım 8, 3 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 8, 3 resimden 2. Acer E5-571-54FL Hard drive Replacement: adım 8, 3 resimden 3.
    • Work your way around the seam with the plastic opening tool carefully prying the base and top cover apart.
    • If you have difficulty with the plastic opening tool, use a metal spudger but be more cautious to not damage or mar your laptop case.
  9. Acer E5-571-54FL Hard drive Replacement: adım 9, 1 resimden 1.
    • When the two halves are separated, carefully lift up the front of the keyboard and touchpad assembly.
    • You will see three ribbon cables attached to the motherboard.
  10. Acer E5-571-54FL Hard drive Replacement: adım 10, 3 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 10, 3 resimden 2. Acer E5-571-54FL Hard drive Replacement: adım 10, 3 resimden 3.
    • Closest to the ribbon cable on the zero insertion force (ZIF) connector is a white locking tab.
    • Carefully lift up on the locking tab with the plastic opening tool to release the ribbon cable. (Picture 2)
    • Remove the ribbon cable from the connector.
  11. Acer E5-571-54FL Hard drive Replacement: adım 11, 3 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 11, 3 resimden 2. Acer E5-571-54FL Hard drive Replacement: adım 11, 3 resimden 3.
    • Closest to the ribbon cable on the ZIF connector is a black locking tab.
  12. Acer E5-571-54FL Hard drive Replacement: adım 12, 3 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 12, 3 resimden 2. Acer E5-571-54FL Hard drive Replacement: adım 12, 3 resimden 3.
    • On each side of the large connector there are two white tabs.
    • Carefully push away from you with the plastic opening tool on each white tab to release the cable. (Picture 2)
  13. Acer E5-571-54FL Hard drive Replacement: adım 13, 3 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 13, 3 resimden 2. Acer E5-571-54FL Hard drive Replacement: adım 13, 3 resimden 3.
    • Once all three ribbon cables are disconnected, lift off the top cover with the keyboard and touchpad.
  14. Acer E5-571-54FL Hard drive Replacement, Hard drive: adım 14, 2 resimden 1. Acer E5-571-54FL Hard drive Replacement, Hard drive: adım 14, 2 resimden 2.
    • The hard drive and carriage are at the lower right of the laptop.
    • Using the plastic opening tool, carefully lift up on the black locking tab of the ZIF connector to release the USB port ribbon cable.
    • Move the USB port ribbon cable out of the way
  15. Acer E5-571-54FL Hard drive Replacement: adım 15, 2 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 15, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the two 4mm screws securing the hard drive carriage in place.
  16. Acer E5-571-54FL Hard drive Replacement: adım 16, 1 resimden 1.
    • Hold the right side of the laptop in place with your right hand.
    • Put the fingers of your left hand along the top edge of the hard drive carriage.
    • Push the hard drive carriage towards your right hand to disconnect it from the motherboard.
    • This procedure may require more force then other procedures.
  17. Acer E5-571-54FL Hard drive Replacement: adım 17, 2 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 17, 2 resimden 2.
    • Lift up on the edge of the hard drive carriage closest to your body to remove the carriage.
    • If doing the motherboard replacement guide, skip the next step.
  18. Acer E5-571-54FL Hard drive Replacement: adım 18, 3 resimden 1. Acer E5-571-54FL Hard drive Replacement: adım 18, 3 resimden 2. Acer E5-571-54FL Hard drive Replacement: adım 18, 3 resimden 3.
    • There are two 3mm Phillips screws holding the hard drive into the carriage. One on either side of the carriage.
    • Hold the hard drive carriage with your non-dominant hand along one side. Ensure one of the Phillips screws is visible.
    • Using a #0 Phillips screwdriver, remove the 3mm screw to release the side of the hard drive from the carriage.
    • Repeat the two previous procedures to remove the second 3mm Phillips screw freeing the hard drive from the carriage.
Sonuç
Aaron Weissman
1.004 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G8, Bailey Fall 2017 UMass Dartmouth, Team S3-G8, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G8
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 354
