Ana içeriğe geç
Acer E5-571-54FL Optical Drive Replacement
Neye ihtiyacın var
  1. Acer E5-571-54FL Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop prior to beginning.
    • Turn the laptop over with the battery closest to your body.
  2. Acer E5-571-54FL Optical Drive Replacement: adım 2, 2 resimden 1. Acer E5-571-54FL Optical Drive Replacement: adım 2, 2 resimden 2.
    • Insert the pointed end of a spudger into the battery release.
    • Slide the release gently all the way to the left.
    • You should hear a sound after the slide is all the way left. This lets you know the battery has disengaged.
  3. Acer E5-571-54FL Optical Drive Replacement: adım 3, 2 resimden 1. Acer E5-571-54FL Optical Drive Replacement: adım 3, 2 resimden 2.
    • Place your hands on each end of the battery.
    • Pull the battery towards your body to remove it.
  4. Acer E5-571-54FL Optical Drive Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Remove the single screw that holds the optical drive in place using the Phillips #0 screwdriver.
  5. Acer E5-571-54FL Optical Drive Replacement: adım 5, 3 resimden 1. Acer E5-571-54FL Optical Drive Replacement: adım 5, 3 resimden 2. Acer E5-571-54FL Optical Drive Replacement: adım 5, 3 resimden 3.
    • Slide out the old optical drive and remove it from the device.
Sonuç
Jennifer Hancock
325 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 445
