Giriş
The trackpad is a component that is likely to malfunction if damaged or altered. Signs of a malfunctioning trackpad include but are not limited to: cursor won’t move, mouse won’t click, cursor keeps disappearing, etc. In addition, if the trackpad comes into contact with any liquid, the trackpad may be faulty. If you’re experiencing any problems with the trackpad of your device, the trackpad may need to be replaced. Follow the instructions in this guide to replace the trackpad.
Neye ihtiyacın var
Power down the laptop prior to beginning.
Turn the laptop over with the battery closest to your body.
Using a #0 Phillips screwdriver, remove a total of eighteen identical 8mm Phillips screws and set them aside.
Remove the screw at the bottom of the track pad using the Phillips #0 screwdriver.
