Ana içeriğe geç
Acer Extensa 4420 Back Panel Replacement
Neye ihtiyacın var
    1. Acer Extensa 4420 Back Panel Replacement, Battery: adım 1, 2 resimden 1. Acer Extensa 4420 Back Panel Replacement, Battery: adım 1, 2 resimden 2.
      • First, make sure that the battery lock is turned off.
      • The battery lock makes it so the battery doesn't accidentally fall out of your computer while it is running.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Extensa 4420 Back Panel Replacement: adım 2, 3 resimden 1. Acer Extensa 4420 Back Panel Replacement: adım 2, 3 resimden 2. Acer Extensa 4420 Back Panel Replacement: adım 2, 3 resimden 3.
      • Then, slide the other battery lock while pulling the battery out.
      FixBot'a Sor
      Yorum Ekle
    1. Acer Extensa 4420 Back Panel Replacement, Back Panel: adım 3, 1 resimden 1.
      Bu adımda kullanılan alet:
      Phillips #00 Screwdriver
      $5.49
      • Unscrew all five screws on the back panel with a Phillips #00 screwdriver
      • The screws will stay in the back panel, so when you remove it, you don't have to worry about organizing the screws.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Extensa 4420 Back Panel Replacement: adım 4, 3 resimden 1. Acer Extensa 4420 Back Panel Replacement: adım 4, 3 resimden 2. Acer Extensa 4420 Back Panel Replacement: adım 4, 3 resimden 3.
      Spudger
      $3.99
      • Take a spudger and start to pry open the back panel. Finish prying it open with your hands.
      • Be extra careful and try not to break any clips in this process.
      FixBot'a Sor
      Yorum Ekle
Sonuç
TheMasterG
1.430 İtibar
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 257
