Ana içeriğe geç
Acer Extensa 4420 RAM Replacement
Neye ihtiyacın var
  1. Acer Extensa 4420 RAM Replacement, Battery: adım 1, 2 resimden 1. Acer Extensa 4420 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • First, make sure that the battery lock is turned off.
    • The battery lock makes it so the battery doesn't accidentally fall out of your computer while it is running.
    FixBot'a Sor
    Yorum Ekle
  2. Acer Extensa 4420 RAM Replacement: adım 2, 3 resimden 1. Acer Extensa 4420 RAM Replacement: adım 2, 3 resimden 2. Acer Extensa 4420 RAM Replacement: adım 2, 3 resimden 3.
    • Then, slide the other battery lock while pulling the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Acer Extensa 4420 RAM Replacement, Back Panel: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • Unscrew all five screws on the back panel with a Phillips #00 screwdriver
    • The screws will stay in the back panel, so when you remove it, you don't have to worry about organizing the screws.
    FixBot'a Sor
    Yorum Ekle
  4. Acer Extensa 4420 RAM Replacement: adım 4, 3 resimden 1. Acer Extensa 4420 RAM Replacement: adım 4, 3 resimden 2. Acer Extensa 4420 RAM Replacement: adım 4, 3 resimden 3.
    Spudger
    $3.99
    • Take a spudger and start to pry open the back panel. Finish prying it open with your hands.
    • Be extra careful and try not to break any clips in this process.
    FixBot'a Sor
    Yorum Ekle
  5. Acer Extensa 4420 RAM Replacement, RAM: adım 5, 3 resimden 1. Acer Extensa 4420 RAM Replacement, RAM: adım 5, 3 resimden 2. Acer Extensa 4420 RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Push the clips in red towards the outside. Doing so will release the RAM. Pull the RAM out.
    • Do this for both RAM modules
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
TheMasterG
1.424 İtibar
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 196
