Ana içeriğe geç
Acer Iconia A1-830 Battery Replacement
Neye ihtiyacın var
  1. Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: adım 1, 2 resimden 1. Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: adım 1, 2 resimden 2.
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Battery Replacement: adım 2, 2 resimden 1. Acer Iconia A1-830 Battery Replacement: adım 2, 2 resimden 2.
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Battery Replacement, Battery: adım 3, 2 resimden 1. Acer Iconia A1-830 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Battery Replacement: adım 5, 2 resimden 1. Acer Iconia A1-830 Battery Replacement: adım 5, 2 resimden 2.
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Matt Champagne
458 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Catania Fall 2015 UMass Dartmouth, Team 4-6, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G6
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
thnks is goood
mo7tarif1997 - Yanıt
Is it okay if the battery bends a slight bit when prying it off?
Doof - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 9,086
