Ana içeriğe geç
Acer Iconia A1-830 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: adım 1, 2 resimden 1. Acer Iconia A1-830 Rear Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: adım 1, 2 resimden 2.
    • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
    • Shut down your Acer Iconia A1-830.
    • Remove any cables or exterior covers from your tablet.
    • Place it on your work space, with the screen facing up.
  2. Acer Iconia A1-830 Rear Facing Camera Replacement: adım 2, 2 resimden 1. Acer Iconia A1-830 Rear Facing Camera Replacement: adım 2, 2 resimden 2.
    • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
    • Do not try to pry apart the top edge on the front side near the front-facing camera.
  3. Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: adım 3, 2 resimden 1. Acer Iconia A1-830 Rear Facing Camera Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
  4. Acer Iconia A1-830 Rear Facing Camera Replacement: adım 4, 1 resimden 1.
    • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
  5. Acer Iconia A1-830 Rear Facing Camera Replacement: adım 5, 2 resimden 1. Acer Iconia A1-830 Rear Facing Camera Replacement: adım 5, 2 resimden 2.
    • Un-stick the battery from the metal plate using the black nylon spudger.
    • Be careful not to puncture the battery while removing it.
  6. Acer Iconia A1-830 Rear Facing Camera Replacement, Rear Facing Camera: adım 6, 1 resimden 1.
    • Remove the piece of black tape covering the rear facing camera ribbon cable connector.
  7. Acer Iconia A1-830 Rear Facing Camera Replacement: adım 7, 2 resimden 1. Acer Iconia A1-830 Rear Facing Camera Replacement: adım 7, 2 resimden 2.
    • Lift up the small white lever on the the ribbon cable connector with the metal tweezers to remove the ribbon cable.
    • Lift out the rear facing camera from the plastic frame with the metal tweezers.
Sonuç
Brendan Coveney
593 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Catania Fall 2015 UMass Dartmouth, Team 4-6, Catania Fall 2015 üyesi
UMASSD-CATANIA-F15S4G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 402
