Ana içeriğe geç
Acer Iconia A110 Battery Replacement
Neye ihtiyacın var
    1. Acer Iconia A110 Battery Replacement, Battery: adım 1, 2 resimden 1. Acer Iconia A110 Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Before taking apart your tablet, make sure the device is powered off.
      • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
      • During this process, the volume button and/or power button may fall out.
      FixBot'a Sor
      Yorum Ekle
    2. Acer Iconia A110 Battery Replacement: adım 2, 3 resimden 1. Acer Iconia A110 Battery Replacement: adım 2, 3 resimden 2. Acer Iconia A110 Battery Replacement: adım 2, 3 resimden 3.
      • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
      FixBot'a Sor
      Yorum Ekle
    3. Acer Iconia A110 Battery Replacement: adım 3, 3 resimden 1. Acer Iconia A110 Battery Replacement: adım 3, 3 resimden 2. Acer Iconia A110 Battery Replacement: adım 3, 3 resimden 3.
      • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
      • You should hear the adhesive ripping as you do this.
      • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Andrea
757 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-42, Maness Spring 2014 Cal Poly, Team 3-42, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G42
4 Üyeler
1Rehber Yorum
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 42
Her zaman: 11,721
