Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
This guide will lead you step-by-step through how to remove the Iconia A110 battery.
Parçalar
Hiçbir parça belirtilmedi.
  1. Before taking apart your tablet, make sure the device is powered off. Pry open the right side of case with the plastic opening tool.  If necessary, keep a tool lodged into the side to keep the case from closing.
    • Before taking apart your tablet, make sure the device is powered off.
    • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
    • During this process, the volume button and/or power button may fall out.
  2. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  3. Pry open the left side of the case with a plastic opening tool.  The backside of the tablet should now separate completely from the front. Pry open the left side of the case with a plastic opening tool.  The backside of the tablet should now separate completely from the front. Pry open the left side of the case with a plastic opening tool.  The backside of the tablet should now separate completely from the front.
    • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
  4. Using the plastic opening tool and spudger, carefully pry up the battery from the case. You should hear the adhesive ripping as you do this. Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
    • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
    • You should hear the adhesive ripping as you do this.
    • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Andrea
757 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 3-42, Maness Spring 2014 Cal Poly, Team 3-42, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G42
4 Üyeler
Bir Yorum
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 10,901
