Giriş
This guide will lead you step by step on how to remove the speaker.
Neye ihtiyacın var
Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
Two 2.0 mm screws (with the bigger head)
Four 2.5 mm screws (with the smaller head)
On the top right side of the motherboard, is the vibration motor. With tweezers, carefully pull the vibration motor out from underneath the motherboard.
With your fingers, carefully disconnect the cable securing the vibration motor to the motherboard. Set aside.
Bir başkası bu kılavuzu tamamladı.
