Ana içeriğe geç
Giriş
How to open the tablet and replace the battery pack.
This video is for replacing the touch screen and LCD display but in the beginning you can see how to open the back cover and how to separate the battery from the tablet. You don't need to remove the mother board.
Please SUBSCRIBE to my channel ツ
Parçalar
Hiçbir parça belirtilmedi.
Videoya Genel Bakış
  1. Switch-off the tablet. If you have a memory card inside, don't forget to remove it! Use a cutter and a plastic tool to remove the back cover.
    • Switch-off the tablet.
    • If you have a memory card inside, don't forget to remove it!
    • Use a cutter and a plastic tool to remove the back cover.
  2. Disconnect the battery connector. The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it . The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
    • Disconnect the battery connector.
    • The battery is stuck to the LCD metal frame with a double side adhesive tape. With a plastic tool carefully separate it .
  3. Li-on Batteri Pack, 3.8V, 2640mAh
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
ZFix
184.202 İtibar
330 adet Kılavuz yazıldı
Takım
Master Techs Master Techs üyesi
Community
307 Üyeler
1.097 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 19,867
