Ana içeriğe geç
Acer Iconia B1-710 Tablet Camera Replacement
Neye ihtiyacın var
  1. Acer Iconia B1-710 Tablet Camera Replacement, Battery: adım 1, 3 resimden 1. Acer Iconia B1-710 Tablet Camera Replacement, Battery: adım 1, 3 resimden 2. Acer Iconia B1-710 Tablet Camera Replacement, Battery: adım 1, 3 resimden 3.
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Acer Iconia B1-710 Tablet Camera Replacement: adım 2, 3 resimden 1. Acer Iconia B1-710 Tablet Camera Replacement: adım 2, 3 resimden 2. Acer Iconia B1-710 Tablet Camera Replacement: adım 2, 3 resimden 3.
    • Unplug the battery from the motherboard.
  3. Acer Iconia B1-710 Tablet Camera Replacement: adım 3, 1 resimden 1.
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Acer Iconia B1-710 Tablet Camera Replacement, Camera: adım 4, 2 resimden 1. Acer Iconia B1-710 Tablet Camera Replacement, Camera: adım 4, 2 resimden 2.
    • Remove the five 3mm Phillips #000 screws. The location of the screws are shown in the above picture, circled in red.
    • Keep the removed screws in a safe place so they can be used later.
  5. Acer Iconia B1-710 Tablet Camera Replacement: adım 5, 2 resimden 1. Acer Iconia B1-710 Tablet Camera Replacement: adım 5, 2 resimden 2.
    • Unplug the LCD by lifting the LCD plug from the white board. The location of the LCD plug is shown in the above picture, circled in red.
    • If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
  6. Acer Iconia B1-710 Tablet Camera Replacement: adım 6, 2 resimden 1. Acer Iconia B1-710 Tablet Camera Replacement: adım 6, 2 resimden 2.
    • Next, unplug the orange strip from the motherboard by gently lifting it. The location of the orange strip is shown in the above picture, circled in red.
    • The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
  7. Acer Iconia B1-710 Tablet Camera Replacement: adım 7, 3 resimden 1. Acer Iconia B1-710 Tablet Camera Replacement: adım 7, 3 resimden 2. Acer Iconia B1-710 Tablet Camera Replacement: adım 7, 3 resimden 3.
    • Unplug the white wire, shown above, circled in red.
    • Unplug the black wire, shown above, circled in orange.
  8. Acer Iconia B1-710 Tablet Camera Replacement: adım 8, 1 resimden 1.
    • Gently, remove the motherboard by carefully lifting it.
  9. Acer Iconia B1-710 Tablet Camera Replacement: adım 9, 3 resimden 1. Acer Iconia B1-710 Tablet Camera Replacement: adım 9, 3 resimden 2. Acer Iconia B1-710 Tablet Camera Replacement: adım 9, 3 resimden 3.
    • Remove the camera from the motherboard with the spudger.
    • Be careful not to damage the camera plug; it is very delicate.
Sonuç
To reassemble your device, follow the above instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Ryan Weber
358 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G5, Baechle Spring 2017 IUPUI, Team S3-G5, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S3G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 352
