Ana içeriğe geç
Giriş
A set of step-by-step instructions on how to remove, and replace the camera on your Acer Iconia B1-710 tablet.
  1. Open the back cover by prying the casing off with an opening tool. Be careful to not pull pieces apart aggressively. There is a wire that could break. Be careful to not pull pieces apart aggressively. There is a wire that could break.
    • Open the back cover by prying the casing off with an opening tool.
    • Be careful to not pull pieces apart aggressively. There is a wire that could break.
  2. Unplug the battery from the motherboard. Unplug the battery from the motherboard. Unplug the battery from the motherboard.
    • Unplug the battery from the motherboard.
  3. Remove the battery.
    • Remove the battery.
    • The battery is lightly glued in, so there may be some difficulty getting it out.
  4. Remove the five 3mm Phillips #000 screws. Keep the removed screws in a safe place so they can be used later.
    • Remove the five 3mm Phillips #000 screws.
    • Keep the removed screws in a safe place so they can be used later.
  5. Unplug the LCD by lifting the LCD plug from the white board. If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
    • Unplug the LCD by lifting the LCD plug from the white board.
    • If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
  6. Unplug the orange strip from the motherboard by lifting it. The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
    • Unplug the orange strip from the motherboard by lifting it.
    • The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
  7. Unplug the white wire. Unplug the black wire. Unplug the black wire.
    • Unplug the white wire.
    • Unplug the black wire.
  8. Remove the motherboard.
    • Remove the motherboard.
  9. Remove the camera from the motherboard with the spudger. Be careful not to damage the camera plug; it is very delicate. Be careful not to damage the camera plug; it is very delicate.
    • Remove the camera from the motherboard with the spudger.
    • Be careful not to damage the camera plug; it is very delicate.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Weber
358 İtibar
3 adet Kılavuz yazıldı
Takım
IUPUI, Team S3-G5, Baechle Spring 2017 IUPUI, Team S3-G5, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S3G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 237
