Ana içeriğe geç
Acer Iconia B1-711 Audio Jack Connector Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Iconia B1-711 Audio Jack Connector Replacement, Back Cover: adım 1, 3 resimden 1. Acer Iconia B1-711 Audio Jack Connector Replacement, Back Cover: adım 1, 3 resimden 2. Acer Iconia B1-711 Audio Jack Connector Replacement, Back Cover: adım 1, 3 resimden 3.
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 Audio Jack Connector Replacement: adım 2, 2 resimden 1. Acer Iconia B1-711 Audio Jack Connector Replacement: adım 2, 2 resimden 2.
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 Audio Jack Connector Replacement, Audio Jack Connector: adım 3, 3 resimden 1. Acer Iconia B1-711 Audio Jack Connector Replacement, Audio Jack Connector: adım 3, 3 resimden 2. Acer Iconia B1-711 Audio Jack Connector Replacement, Audio Jack Connector: adım 3, 3 resimden 3.
    • Unscrew 2x Philips screws
    • Disconnect and remove the Audio Jack Board flex cable.
    • Remove the board with the Audio Jack Connector.
Sonuç
ZFix
191.368 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.466 adet Kılavuz yazıldı
Bir Yorum
Can anyone suggest part number for whole jack board or just of jack?
Alexander Zaripov - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 584
