Ana içeriğe geç
Acer Iconia B1-711 Loudspeaker Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Iconia B1-711 Loudspeaker Replacement, Back Cover: adım 1, 3 resimden 1. Acer Iconia B1-711 Loudspeaker Replacement, Back Cover: adım 1, 3 resimden 2. Acer Iconia B1-711 Loudspeaker Replacement, Back Cover: adım 1, 3 resimden 3.
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 Loudspeaker Replacement: adım 2, 2 resimden 1. Acer Iconia B1-711 Loudspeaker Replacement: adım 2, 2 resimden 2.
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 Loudspeaker Replacement, Loudspeaker: adım 3, 2 resimden 1. Acer Iconia B1-711 Loudspeaker Replacement, Loudspeaker: adım 3, 2 resimden 2.
    • The loudspeaker is stuck on the Rear Cover with a double side tape.
    • Use a sharp tool remove it.
Sonuç
ZFix
191.368 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.468 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 474
