Ana içeriğe geç
Acer Iconia B1-711 V1-711 Logic Board Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Acer Iconia B1-711 V1-711 Logic Board Replacement, Back Cover: adım 1, 3 resimden 1. Acer Iconia B1-711 V1-711 Logic Board Replacement, Back Cover: adım 1, 3 resimden 2. Acer Iconia B1-711 V1-711 Logic Board Replacement, Back Cover: adım 1, 3 resimden 3.
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 V1-711 Logic Board Replacement: adım 2, 2 resimden 1. Acer Iconia B1-711 V1-711 Logic Board Replacement: adım 2, 2 resimden 2.
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 V1-711 Logic Board Replacement, Battery: adım 3, 2 resimden 1. Acer Iconia B1-711 V1-711 Logic Board Replacement, Battery: adım 3, 2 resimden 2.
    • With a long plastic tool like a spudger, unstick the battery from the metal LCD shield.
    • Lithium Ion Battery Pack - 3.8V, 2710mAh
  4. Acer Iconia B1-711 V1-711 Logic Board Replacement, Audio Jack Connector: adım 4, 3 resimden 1. Acer Iconia B1-711 V1-711 Logic Board Replacement, Audio Jack Connector: adım 4, 3 resimden 2. Acer Iconia B1-711 V1-711 Logic Board Replacement, Audio Jack Connector: adım 4, 3 resimden 3.
    • Unscrew 2x Philips screws
    • Disconnect and remove the Audio Jack Board flex cable.
    • Remove the board with the Audio Jack Connector.
  5. Acer Iconia B1-711 V1-711 Logic Board Replacement, Camera: adım 5, 3 resimden 1. Acer Iconia B1-711 V1-711 Logic Board Replacement, Camera: adım 5, 3 resimden 2. Acer Iconia B1-711 V1-711 Logic Board Replacement, Camera: adım 5, 3 resimden 3.
    • Remove the Audio jack flex cable.
    • Remove the metal plate which is placed on the camera connector.
    • Disconnect the camera flex cable.
  6. Acer Iconia B1-711 V1-711 Logic Board Replacement: adım 6, 1 resimden 1.
    • Remove the camera.
  7. Acer Iconia B1-711 V1-711 Logic Board Replacement, Microphone: adım 7, 3 resimden 1. Acer Iconia B1-711 V1-711 Logic Board Replacement, Microphone: adım 7, 3 resimden 2. Acer Iconia B1-711 V1-711 Logic Board Replacement, Microphone: adım 7, 3 resimden 3.
    • Remove the tape from the microphone.
    • Disconnect the Microphone wires and remove the Microphone.
  8. Acer Iconia B1-711 V1-711 Logic Board Replacement, Logic Board: adım 8, 3 resimden 1. Acer Iconia B1-711 V1-711 Logic Board Replacement, Logic Board: adım 8, 3 resimden 2. Acer Iconia B1-711 V1-711 Logic Board Replacement, Logic Board: adım 8, 3 resimden 3.
    • Remove the green rubber and disconnect the touch screen flex cable.
    • Disconnect the 4 coaxial antenna cables (Wi-Fi, GPS, 3G).
    • Carefully unstuck the metal folio from the LCD display flex cable.
    • Remove the 3x Phillips screws.
  9. Acer Iconia B1-711 V1-711 Logic Board Replacement: adım 9, 3 resimden 1. Acer Iconia B1-711 V1-711 Logic Board Replacement: adım 9, 3 resimden 2. Acer Iconia B1-711 V1-711 Logic Board Replacement: adım 9, 3 resimden 3.
    • Lift the board from the side of the battery connector and turn it around the display connector on 360 degrees.
    • Be careful for the flex cable!
    • Disconnect the LCD display flex cable.
  10. Acer Iconia B1-711 V1-711 Logic Board Replacement: adım 10, 2 resimden 1. Acer Iconia B1-711 V1-711 Logic Board Replacement: adım 10, 2 resimden 2.
    • This is the Logic board.
Sonuç
ZFix
191.341 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.541 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 7
Her zaman: 955
