Ana içeriğe geç
Acer Iconia B1-720 Microphone/Speaker Replacement
Neye ihtiyacın var
  1. Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: adım 1, 3 resimden 1. Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: adım 1, 3 resimden 2. Acer Iconia B1-720 Microphone/Speaker Replacement, Rear Case: adım 1, 3 resimden 3.
    • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
  2. Acer Iconia B1-720 Microphone/Speaker Replacement: adım 2, 3 resimden 1. Acer Iconia B1-720 Microphone/Speaker Replacement: adım 2, 3 resimden 2. Acer Iconia B1-720 Microphone/Speaker Replacement: adım 2, 3 resimden 3.
    • Slide the tool along until you have completely separated the rear cover.
    • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
  3. Acer Iconia B1-720 Microphone/Speaker Replacement: adım 3, 2 resimden 1. Acer Iconia B1-720 Microphone/Speaker Replacement: adım 3, 2 resimden 2.
    • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
  4. Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: adım 4, 3 resimden 1. Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: adım 4, 3 resimden 2. Acer Iconia B1-720 Microphone/Speaker Replacement, Microphone/Speaker: adım 4, 3 resimden 3.
    • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
    • Tug gently on microphone to remove from slot.
  5. Acer Iconia B1-720 Microphone/Speaker Replacement: adım 5, 2 resimden 1. Acer Iconia B1-720 Microphone/Speaker Replacement: adım 5, 2 resimden 2.
    • Unwind the wire from the running channel.
    • To remove microphone, follow same steps.
  6. Acer Iconia B1-720 Microphone/Speaker Replacement: adım 6, 2 resimden 1. Acer Iconia B1-720 Microphone/Speaker Replacement: adım 6, 2 resimden 2.
    • Unplug connector from motherboard.
    • Follow same procedure to remove microphone.
    • Unplug the microphone in a similar fashion as with the speaker.
Sonuç
Phillip Keavey
319 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-1, Lauer Spring 2015 Michigan Tech, Team 1-1, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G1
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 688
